Setting up several components with PL/ML/RCA
Hello, I bought a bunch of B&O components and I'm trying to set them up correctly. Unfortunately there were not all cables included so I want to make sure everything works out as I imagine, before buying the missing cables. In detail I got a: -BeoCenter 6-26 -BeoCenter 2300 -a pair Beolab 6000 -BeoLink Converter 1611 and I want to connect a "modern" Satellite-Set-Top-Box via HDMI->DVI cable.
  1. When I connect the BeoCenter 6-26, BeoCenter 2300 and both Beolab 6000 via PowerLink I should be able to hear CD and Radio from the BC 2300 on both BL 6000 and also my TV audio from the BeoCenter 6-26, correct?! In my situation I would wire them the following way (PLC - PowerLink Cable): BL 6000 (left) ---- PLC ---- BC 2300 ---- PLC ---- BL 6000 (right) ---- PLC ---- BC 6-26
  2. I already tried out the HDMI-DVI connection from my STB to the BC 6-26 and this is running flawlessly. But obviously without audio. Now I'm thinking how to get the audio signal from the STB (2x RCA) to the BC 6-26. I got the Beolink Converter 1611 and as far as I understand I could use the AUDIO AUX LINK on the Converter to input the RCA signal and connect it via Masterlink to the BC 6-26, right?! This would look like this (MLC - Masterlink cable): STB ---- RCA to AUX ---- Beolink Converter ---- MLC ---- BC 6-26
Now my final question would be if the connection sheme #2 works out, will I also be able to hear the audio from the STB on the pair of BL 6000? Or should I use the PowerLink port on the Beolink Converter in that case? Should or do I have to drop the Masterlink connection to the BC 6-26 in that case? Thank you for your responses Regards Konrad
Hi and welcome to Beoworld! You need to connect the Beolab speakers to either the TV or the BC2300 but not both.  Let's assume initially that you decide to connect them to the BC2300. The Beolink Converter allows you to connect the BC6-26 to the BC2300 so that you can chose to hear TV audio through the BC2300 and vice versa.  To use this, connect the TV by Masterlink cable to the 1611 converter, and then connect a 7-pin DIN to DIN cable between the 1611's AAL socket and the BC2300's AUX socket. Once you have done this, the TV and BC2300 need to be in the correct Option Settings.  You need the TV in V.OPT 1 and the BC2300 in A.OPT 1.  Let me now what remote you have and I will tell you how to set this up. The best way to get the hdmi audio into the BC6-26 is to use an hdmi audio extractor, as explained here:
If as an alternative you connect the Beolab speakers to the TV's Powerlink socket, then you need to add a powerlink cable between one of the the BC2300's Powerlink sockets and the 1611 converter's Powerlink socket.  In this case, you would want the TV to be in V.OPT 2 and the BC2300 to be in A.OPT 0.
You should be able to connect this straight to your BC6-26 red/white audio input sockets (labelled AV3). This assumes that your STB can output hdmi and analogue audio at the same time. I have to check that, but I'm quite sure this should work!
Thank you very much. I will need some time to test everything and set it up but I will definately come back when succesfull!
