Hi Guys
After opening up the Beocentre 7000 does one have to remove the cassette mechanism to clean and change the belts or is this with it done in situ but unscrewed?
If it needs to come out how do I get access under the record deck to unplug the wiring loom please?
Beocentre 7000 cassette belts
I’ve sorted this thanks. I discovered that the record deck also lifts up from the rear which allows the cassette looms to be unplugged and thence the cassette deck removed for servicing.
Sounds like a Beocenter 7000 rather than a Beomaster 7000.
Yes very sorry Dillen it is the Beocentre 7000 as you say
