Beomaster 2400-2 Volume weirdness
Hello, picking up on my Beomaster 2400-2 2901. After new bulbs and recap The volume control is exhibiting odd behavior: When pressing Down, ~50% of the time the volume increases, as does the Up light.  Up is always up.  In addition when I change volume either way (by holding) the indicator lights seem to shift the other way a tiny bit, almost like settling back a bit.  There 12.4v on the 12 v rail (too high?) but everything on board 3 is tested and fine. Also, sometimes the vol lights seem to pulse left/right, but that may be due to my LED shop lights. I am also fascinated by how the volume controls works. -Max
Well pretty easy fix.  Replaced 3IC1 (CD4011) and issue is solved!
