Beomaster 3500 and BeoLab 4000 / 6000
Hi all,
I own a Beomaster 3500. Is it possible to connect BeoLab 4000 or 6000 active speakers to the system? If so, how to?
I realise i cannot use the speaker output, since it would 'kill' active speakers.
Thank you in advance!
Yes it is. You will have to use the connectors marked Powerlink and connect to the speakers with Powerlink cables
Further to madskp's response, I think the Mk3 Powerlink cables will be fine in this situation - available from Sounds Heavenly here:
Thanks for your replies! I will go ahead 🙂
