Beomaster 4000 tuning lights & meter
I have just refurbished my BM4000 with the Danish sound parts kit, everything is working well apart from the tuning signal lights and meter. Both side of the lamps have 15 volts (hence no light) and from the diagram there should be 8.8v at TR11-15.
Are there any tips or common faults with this circuit ?
Paul
Can I also add that the collector of TR9 has zero volts, I can't figure why.
Any ideas?
Cheers
Paul
OK folks
I have fixed the problem, I just needed to increase the level in the front end by adjusting trim pot 74. All lights working now.
Paul
