Hi all,
I have serviced this Beomaster and changed all old caps and tantalums two years ago. Now the machine has developed an odd problem.
When I power it on, no issue. It plays well and the sound is nice. But after some time the sound output will slowly drop to almost nothing. Very faint (but output still responds to volume control). It happens on both channels.
If I power down the machine and let it 'cool' for some time and power it on then the sound is back. But it will also die down very quickly. When I let it cool for a night it will play well for some 20 minutes and then the sound will drop again.
I am wondering what is the most common cause of this issue that affects both channels.
Many thanks for your thoughts,
Bert
Beomaster 4400 - Sudden drop in sound?
Hmmm, opened it up and it seems I did not change the main filter caps. But they test allright on my ESR meter. Also I can't see them failing at the same time with the same issue.
Bert
Odd.
Mine still runs on its original main caps too.
No hum anyway?
I’d suspect a switch problem.
Jacques
Have you checked the thermal compound and mica insulators?
Sometimes, the thermal compound is fine after decades, other times it has dried out and shouldn't be trusted.
Mica insulators can split between layers. These will look like there are air bubbles in the mica. Mica is a good thermal conductor, air is a good thermal insulator.
Disassembling, inspecting and replacing the thermal compound with modern, higher performance compound doesn't take that much time. Even if it wasn't needed, it can provide peace of mind.
Addition: The above comments are primarily targeted to the power supply components. These might affect both channels simultaneously. Also, if you have a FLIR camera, it is really useful for debugging potential thermal issues.
Glitch
Check for cracked solder joints, particularly where connectors and the piggy-back boards are soldered in.
Does it run warm on the cooling fins? If so check the idle current settings.
Hi all,
- When I serviced the machine all output transistors were replenished with new washers and thermal compound
- There is no hum at all and the filter caps register as fine (outside of circuit)
- Sorry, no FLIR camera but nothing is getting really hot on the board aside from the transistor with the giant 'star' heatsink (which I would expect to get hot). But it doesn't seem to be failing and a failure here would be apocalypse on the power supply
- There is one (1) component which I think is an old thermistor. It is in the middle of the heatsink. On inspection I saw that it's very long legs were touching. That is not good. But I don't know how to test the bugger.
Bert
You dont say if the falling volume is occurring on all inputs i.e. FM tuner/phono/tape ?
Craig
And incidentally one way of testing the thermistor is to blow a hairdryer over it and the fault relay should activate and shut the amp down.
Craig
Is the thermistor R40? If so, the service manual calls it out as "50 0hm 30% PTC". You can test it by removing it from the circuit, hooking it to an ohm meter and observe the resistance as you heat it up with something like a hair dryer.
I would also make notes of all of the voltages from the power supply and see how they change with time and temperature. From the schematic, it appears that many of the voltages are referenced from the +15v supply. If this dropped down, many of the other signals would follow.
Glitch
One way of determining if the 15v rail is falling off is to monitor the power ON lamp as this is fed from that supply.
Craig
