BeoMaster 5 and A.AUX
Right!
However, the easiest way would be to use one of these:
Login to view image
Please notice that Steve is only shipping to the UK for time being - but the Behringer can be bought elsewhere….just do a search for it.
And…..if you want to connect more than one device, you’d need some kind of switch too.
As for the 2nd question - I remember back in the days, that I had a stock external USB drive connected….so yes that should work!
I would however, not recommend it - it will be much easier to use a PC/Mac for this, because you will have to tag the files properly in order to have these searchable and showing coverpics etc on the BS5.
Good morning together,
my BeoMaster5 has not been in standby mode for quite some time. The BM5 is linked to BS5 and BL 8000. What strikes also the tracer is not functioned for switching off and turning on at the back any more. Is this a software or hardware issue that the board is defective. Also have already tested different options via the F8 key with connected keyboard at restart, but came to no result.
Does anyone have any advice on what it might be?
Thank you in advance greeting Andreas
Hi B&O lovers,
Using a Beomaster 5 connected to a Beosystem 3 via ML in a BV9. I want to attach a separate CD player to the Beomaster 5 via USB / AUX cables with the Behringer UFO0202, so my questions are:
1, Can I invoke the A.Aux from the Beomaster 5 without a Besound5 attached?
2, Is it possible to replace the 'Web' selection option from the native Beomaster 5 menu with A.Aux?
Would appreciate any help from budding developers or long term owners who have achieved something similar.
A
