Beomaster 5 connection to BV 9
Hi guys, have problems with connecting bm5 to bv9. What is the right way to do it? It's visible but can't use with remote (Beo4) There is also BeoSound 5 connected but if I choose N.music with remote the tv screen shuts off. Any good advice?
Use the PC command to view the beomaster  5 on the BV9
Master Optician
Beomaster is already under pcs. In my case pc-command don't work so it's configured under DVD2/AV4. (pc is not highlighted / available  on TV screen "menu/connctions). So PC is AV5 but there's no AV5 input in the tv or there is but it's already in use for Beosystem 3 which is for the tv. This of course mean also that I can not use remote to configure Bm. Is there some possible way to configure either bv or beo4? Some other on top of those I already know?
