Beomaster 5500 source selection
My BM5500 has developed a fault when choosing sources. If I select CD, TAPE or phono it will flicker between sources in the display and a relay is clicking continuesly. If I select radio this doesn't happen The last thing it was used for was in a test scenario with a Beolink converter connected to the TAPE2/AUX input if this can give any hint as to what could be the reason for this behaviour. Any ideas where to start looking? Thanks in advance
There is a LED driver chip MM5450 on the display board. If there is a problem with overload of a segment... the chip has internal led driver resistors... it will have problems to activate the defekt segment causing a power failure of the display/cpu... that's the flicker. Try the amp without speakers to activate from 0 to 64 to check all these segments. Usually there will be a "8" problem... and a problem with the source led. It can be the chip or the power supply itself. Replacing the chip is very skilled work and the chip is hard to get. Usually some caps in the power supply are the cause...
7-segment and Led's for the source are done with the same chip... and the relais.
Ok thank you, then I will take a look around there when I ger it open
Had some time look further into it today.
About the relay clicking, now that I have the BM5500 open I can see that it is the relay behind the plug PCB that is clicking rapidly But I noticed that the relay on the PSU board (betwen the transformer and the large caps) is also clicking once in awhile if that is an indicator for something.
