Hi Beoworld.
I’m looking at a fault in my Beomaster 6000 Type 2251. The problem is when I press the volume up or down button the volume goes down and the volume motor continues to run like it would go down below scale. I can then press reset button or any preset volume button and it’ll stabilize and volume motor stops. The rubber band is good. Another thing is that the volume won’t go higher than 20 on the scale, I can manually turn the volume up to maximum without the rubber band on.
If you have any idea what I should look for i would appreciate it greatly.
Beomaster 6000 volumen goes down
Going from memory so I might be off a bit... Check the wire connections between board 5 and 6 for cracked solder joints. Adjust the volume control trim pots on board 6 per the service manual. Clean or replace any trim pots that don't adjust properly. Make sure that the plastic film display slider window moves freely. I may have missed something, but what this should be a decent start.
Replacing the belt with a new one from Danish Sound Parts would be good preventative maintenance. The belt is the weak link in the design and a new one will save you headaches.
Glitch
