Hi. I recently had a Beomaster 6500, I wonder one thing - when I start the device from standby mode, regardless of whether it is RADIO, AUX or PHONO, the receiver starts at volume level 62, is it possible to change it to a lower level somewhere?
Beomaster 6500 - starting volume settings.
Hi suhy2, according the MCP 6500 manual, you need to press SET, to store the settings you want it to start with:
Login to view image
Hope this helps.
Johan
Login to view image Hope this helps. Johan or with a BL1000 set the volume, press sound, store. (principle is the same on Beo4, but correct buttons can be hidden in the menu's; see the beo4 manual)
Thx! It`s working. :)
