Beomaster 7000 front panel (sometimes) not working
My Beomaster 7000 has begun to display a strange behaviour. After some time on standby, the left button will not turn the unit on again. If I then use a remote control to turn it on and then off, the front panel button wil work again. However, after some time - e.g. if I want to turn it on next morning, the button will not work again. Argh.
I initially thought it was the backup battery that needed replacement, so I did that. Same result.
Can anyone point me in a direction to what I should look for?
Of course I can just use the remote but it annoys me that the Beomaster is not working 100% as it should.
Strange - it seems that the problem fixed itself. Now it works every time.
The switches can have oxidation. There ist just a switch going to the 8155 port chip, nothing elase but a cap an d a resistor.
The switch itself can have a problem. You can measure it, resistor 0 or very high.
But what helps: replacement or some current around 200-500mA... the current will clean it. But only if disassembled or the cpu will die.
Second possibility: there is a connector from the front pcb to the cpu board. The connector can have the same oxidation, but can be cleaned.
