Beomaster 8000 right channel is very hot
Hi, My Beomaster 8000 is getting very hot [unable to touch] in less than a minute from turning it ON. First, I replaced the rear right side cooling fins assembly [with the transistors], with a good working one - didn't help. Second, I replaced the amplifier board with a good working recapped one - didn't help. Left channel is cool. Any idea what can be the problem? Thanks
This is the unit with the heat problem I'm working on right now.
Does it play, sounding normally, when you switch it on? Is there a trimmer for idle current?
The sound is good from all speakers outputs. Don't know where is the trimmer for idle current.
Good thing, the trimmers were already replaced. Follow the service manual to set bias.
Jacques
Tanks, I have set the trimmers using the service manual- problem solved.
