Hellomy name is Wojtek and this is my first time on this forum and I have a problem.
I bought couple weeks ago beomaster 900k.Works good but I have a problem with stereo mode
When I turn on cassette mode or gramophone stereo light turn on, but when I turn beomaster on radio mode fm stereo light won't turn on.
Does anybody had this same problem?.
Beomaster 900 k problem with stereo light
The stereo decoder module was an optional extra in Beomaster 900K.
Not all Beomasters had them installed.
If no stereo decoder module has been installed, FM reception will be mono only, and the stereo indicator won't light up.
Would you show me photo with stereo decoder to check this thing on my beomaster.
Maybe I don't have this item on radio but why stereo light flashing when I turn on cassette mode? is it normal.
The decoder is the module to the right of the amplifier module in this photo.
It has no visible leads out side this.
Login to view image
When Tape or Phono is selected as source, the stereo light should be lit.
If it flashes, it could be because of a bad switch contact or the lamp is not securely fixed in
its socket. Or the lamp itself is on its way out.
(Photo from www.vintage-radio.net)
