I have a strange issue with connecting a Beocord 9000 to Beomaster 8000:
When connected with a 7 pin Din cable, there is no sound from the left channel. Other functions works well.
When connected with a 5 pin Din to RCA cable - the sound is fine from both channels.
Same issue on Tp1 and Tp2 inputs. Same issue with beocord 8004 and another beomaster 8000. Same issue with different cables (5 pin Din and 7 pin Din).
When connecting another source (CD player) with RCA to 5 pin Din cable - sound is fine in both Din inputs (Tp1 & Tp2).
Cables are aftermarket cables.
Any ideas? Thanks
Connecting beocord 9000 to Beomaster 8000
Check continuity in the cables.
Thanks,
Continuity in the cables is okay.
Do I need an OEM cable?
Difficult to diagnose from a distance, but I have seen aftermarket cables with
wrong pin configurations.
