For some reason my N.Radio updates got stuck on 13/2/2020 and I started missing newer stations and some older stations didn’t play anymore. I saw mention of the same problem in several posts but not a real proven solution.
So I contacted B&O Support and the solution appeared to be very simple: go into the Maintenance menu and Delete Databases! After that BeoMaster 5 reboots and starts downloading the complete actual N.Radio database again!
And this worked fine for me: after an hour or so I got 67397 ‘new’ stations re-downloaded from the portal. Some hours later the logos were also present. My failing stations play again now and I see plenty of new stations appearing.
So thanks to B&O Support for their clear, simple and effective solution :)
This is the link to the document:
Thanks for this Luc. Sorry that you had problems posting - I think the spam filter didn’t like the link but it all works now.
Hello,
Is it true that B&O stopped updating the N.Radio stations on the BeoMaster5?
If so, is there a way to add/edit stations manually?
The last update was in 2022.
Kind regards,
Luc
