- Beomaster 6500,
- Master Control Panel 6500 + a B&O "stick" remote control I don't know the reference of,
- Beogram 6500,
- Beogram CD 6500,
- Nakamichi DR-3 (sorry, no B&O),
- 120 W / 4 Ohms ALR Nummer 3 loudspeakers, a former german brand of 1994, still in perfect condition.
- If such connectors are ok, according to the specs, a POWERLINK DIN connector should carry both left and right signals, which Beomaster output should I use? Left or Right? Any of them?
- What do you think about the adapters that I have mentioned above? (BTW, what is the difference between both articles? Beside the price, I see none.) Would you recommend some other adapter? I seek the best possible quality.
