Hi All,
I have obtained a Beoplay A2 first edition with supposedly a broken battery.
So I swapped the battery with 2 other ones and it worked, but it doesn't charge the battery.
The adapter gives 15v, the orange led is on.
But when I measure the battery itself the voltage goes slowly down...
I looked at the mainboard with a magnifier, but I didn't directly saw something odd like oxidation points.
The power connector makes proper contact.
Is there something else that I can check?
I have also another A2 Active wich I can charge the batteries without problem (2 original, 1 after market.)
TIA
A.K.A Capt’nGerard on the Discord
