Beoplay A9 (5th GEN) and Sonos Port
Hi guys, I have a "problem" Have Beoplay A9 (5th GEN) and Sonos Port connected to it via ( RCA to USB-C A9 G5 does only have USB-C (dongle included)) However I can not get the get the volume "up and down" to work correctly. I can pick line in on A9, but I can not control volume through Sonos app The volume is stuck at predefined level and I need to open up the B&O app to change the Volume! Is there a workaround? Running: 3.4.1( software on A9) I have a transmitter1 + pair of beoplay 17 and sonos port connected to transmitter 1 via Rca and that is fine With hope of help BW Mr.B
In the Sonos app, the Settings tab, tap System. Select the room with your Port, then tap Line-Out Levels and choose "Variable" instead of "Fixed" or "Pass-Thru" (you wish, be serious).
