Beoplay M3 line in sound skipping
I'm trying to create a setup where I connect a Beogram to a Beoplay M3 via line in and then do multi room to a Balance. The M3 is only supposed to be the gateway to the balance.
However the sound is skipping all the time, so the setup is basically useless.
If I disable delay in the B&O app the M3 plays just fine, but then I cant do multi room...
Any ideas?
Hi Peter and welcome to Beoworld!
Have you tried changing the Line In detection level to 'disabled'? It's the setting above the delay setting.
Hi Guy,
Thank you.
No haven't tried that, will do so when I'm back home tomorrow and report back.
I spoke with B&O support today and they suggested that it could be due to my mesh network..
Peter
After disabling my mesh network and just going with one router everything now works fine.
https://update.bang-olufsen.com/products/b4ebddbebc6542ad87534e36f49d6a9a Thanks. Yes the software is fully updated.
