Hello all! ( new member.) As I hotspot all my devices from my Android phone, I don't have WiFi available. I was able to achieve a stereo setup of the M3s with the dual channel function on my Galaxy s20 FE, however it was not stable with the 4.2 Bluetooth. My only option was to upgrade the Bluetooth to 5.0. I achieved this with a pair of Tunia Flyfly LDAC USB-A Bluetooth 5.0 dongles ( available on Amazon from the States,) which fit to the micro-B port with a quality adapter. The 3.5 audio plug also fits to the rear of the speaker. Each dongle's software can be updated and customised through the apps provided. Equaliser should be set to Addiction, LDAC control turned off to provide the most stable connection by SBC and the phone equaliser set to normal. The M3s should be reset to defaults and the Bluetooth lights will work as is. I subscibe to Tidal, which provides HiFi for the same cost of Spotify Premium and you can transfer a < 500 song playlist for free. Being unable to access the B&O app without WiFi, I used a volume booster app to provide the required level of volume from the phone's control. The sound quality is equivalent to a $4k B&O setup for the cost of an M5. Superb stereo sound!
