| Beo 4 | Beolink 1000 MkI & II | Beolink 1000 MkIII & IV |
| [red] | [SHIFT] [<] | [SHIFT] [\/] |
| [blue] | [SHIFT] [>] | [SHIFT] [/\] |
| [green] | [SHIFT] [<<] | [SHIFT] [<<] |
| [yellow] | [SHIFT] [>>] | [SHIFT] [>>] |
| [MENU] | [SHIFT] [TEXT] | [MENU] |
| [LIGHT] | [SHIFT] [LINK] | [LIGHT] |
| [GO] | [PLAY] | [PLAY] |
| [DTV] | [SATELLITE] | [SAT] |
| [DVD] (Note 1) | [SHIFT] [CD] | [SHIFT] [SAT] |
| [PC] (Note 2) | [SHIFT] [STORE] | [SHIFT] [STORE] |
| [DVD2] | [SHIFT] [V.TAPE] | [SHIFT] [V.TAPE] |
| [V.AUX] or [DTV2] | [SHIFT] [TV] | [SHIFT] [TV] |
| [A.AUX] | [SHIFT] [RADIO] | [SHIFT] [RADIO] |
| [N.RADIO] (Note 3) | [PHONO] | [PHONO] |
| [N.MUSIC] (Note 4) | [SHIFT] [A.TAPE] | [SHIFT] [A.TAPE] |
| [STAND] (Note 5) | [PICTURE] | [PICTURE] |
| [SPEAKER] | [SOUND] | [SOUND] |
| [RESET] | [RESET] | [SHIFT] [MUTE] |
| [TURN] | [TURN] | [SHIFT] [SOUND] |
- On the Mk1 'AV' Beo4, you select DVD by adding CDV (which has the same IR codes) to the LIST function.
- It was not possible to add PC on early Beo4s (you need BL1000 or a newer Beo4, at SW3.4 or later)
- PHONO still available on earlier Beo4s, possibly prior to SW4.2?
- N.MUSIC replaces A.TAPE2 or A.TP2 from Beo4 SW4.2
- Not exact link: On Beo4 use V.SETUP (for TUNE) then LIST for PICTURE
