Beoremote one - faulty?
It suddenly stopped talking to the Theatre, I then did a factory reset and now it will not pair to the Theatre again. I have followed all the instructions. The only thing I haven't done is a factory reset on the theatre as I just got all the settings sorted, I wish it had a "upload settings" function so that you don't have to start again. Is there any thing else the remote can pair with for me to test? ie phone?
In the old forum, @riverstyx claimed "yes": https://archivedforum2.beoworld.org/forums/p/22895/189582.aspx#189582
No, as the remote just stopped and didn't think to unpair using the Theatre app. I have to re-do wires anyway soon, so I'll do another reset over the weekend on the Theatre and let you guys know how it goes?
Ha, the pairing with the phone worked straight away, guess its not faulty then! Here goes the factory reset on the Theatre again......
I have commented on the main Theatre thread that there is an issue in comms beteew the BR1, BeoApp and theatre. Too many configurations of the TV/Music Lists in the app crash the BR1 and the BR remote no longer updates.  Configure a PUC with the source active (or the 2nd PUC), causes a lock-up. Hard reset of Theatre seems the only way for now. Reset of the BR does not work, not a soft reboot of the theatre.
