Are these two transformers the same? BeoSound Century 2000
Hello everyone.
I have two functioning transformers that came out of a BeoSound Century 2000, one from the USA and one from Denmark.
I recently fixed my broken Century by swapping in parts from a European model, but am left wondering if I actually needed to purchase the European transformer.
As you can see in the photo (European is on top, USA on bottom), the only thing that is different is how the wires are connected on the bottom. The part number is the same, and the fuses listed seem to be the same as well.
So my question is: if I were to re-solder the transformer from the USA to match the same wiring on the European model, would it work? That way I could return the transformer I just purchased, and the other won't go to waste / take up space.
Thanks in advance!
Yes - the service manual shows three different wiring schemes for the same transformer: 120v, 230v and 240v.
The fuses listed are actually on PCB 5, so if you haven't replaced that with the USA one you will be fine.
(Sorry for the edits - hope I haven't confused you!)
Further to the above, Module 10 (Mains) has an additional transformer that is wired differently according to the supply voltage, so you need to make sure this matches your mains supply.
Ah okay thank you for the response!
I'm unfamiliar with the names of the parts but I believe PCB 5 is the one after the transformer that sits under the door motor, correct?
And 10 Mains seems to be the one where the power cable is plugged into and then has a wire that runs into the transformer, correct?
I have switched both mentioned parts out for European versions, so I think if I were to change the wiring on the transformer it would work just fine...?
Hmm unsure which part this refers to ( very new to this :) ), but it's the American one.
I haven't noticed anything working incorrectly, although I've only used it for cassette tapes.
And great! I will go ahead and give this a try then!
I think that the US tuner version adds AM frequencies if that's any use to you!
