BeoSound 3000 - Type Numbers
Hi everybody,
does a type list exist, explaining the differences between types of the BS3000 ?
Is Type 2671 ok, or should it be avoided as it seems to be the first type for BS3000.
Thank’s for your help
gerard
As far as I know (from the Service Manual) type numbers simply relate to the country of use (and corresponding supply voltage):
Login to view image
Did I read somewhere that the 'small clamper' was abandoned because it exposed most of the spinning disc, thus flashing light reflections from the surface (depending on CD artwork), and therefore risks triggering epileptic fits? I can only have read this on Beoworld or in Tim Jarman's book!
If you look at the service manuals on the site, then the one for the BS3000 shows the small clamper, and then one for the BS3200 shows the large clamper.
Comparing part numbers between the two schematics, the only new part number is the 'cover f/clamper'. (9007 in the diagrams below)
BS3000:
Login to view image
BS3200:
Login to view image
EDIT: And there's a thread here where Joeyboygolf confirms that they are interchangeable:
The small clamper version is shinny and the big clamper is mat.
EDIT: unless you replace the whole fascia, sorry.
