- I've recently replaced the cd laser part through kose trading in copenhagen; though after quite the sum it did not resolve the cd play function.
- After running testmode 27 (1. Enter standby mode. 2. then Press, "Display and the numbers 0 2 5 8" in 2-sec-interval sequence). I receive TM error code "4" Which the 3200 service manual describes as :
Beosound 3200 CD player troubleshooting
Hi guys,
So my beosound 3200 is not playing CDs. Agh! I simply see the message "LOAD CD" , even after loading various CDs into the tray. The CD never starts, and there is no spin.
Actions:
Hi and welcome to Beoworld!
Althoug it's not specific to BS3200, have a read through of this thread:
Total novice here, and read through your resourceful link!
SMD caps:
I'm eager to order the relevant capacitors SMD and try my take at soldering/desoldering the servo pcb. Any tips you have regarding the twisting technique or otherwise? Also, in order to get those, what sites do you typically quote/order from that proved successful in repairing the thing? I saw a post on the thread you sent where someone referred to ordering standard smb's as preferable.
Cable:
I also think it may be a subtle and minor ribbon cable tear that doesn't transmit the signal that the disc is loaded to start the spin/play. You'll see in the the images I'm attaching. Any advise on sourcing that type of thin film cable and common recommendation/youtube of the process/skill required to solder for beginners given your expertise. :-)
Image note:
You will see the center of the small blue circle in the first image is where the tear is located, on the back of the unit running to the disc spindle - a part manufactured by Machubi - that holds the CD in place.
Regarding removal of SMD caps see my two last posts here
Gents! Hot update! Kose sent me a cd laser part that was the entire servo board motor, optical reader housed together and after replacing that …..eureka! The cd player function is back on and im happy seeing the discs spin and audio waft through the air !
its been decommissioned for quite some time and a lot of troubleshooting. I never got around to changing the capacitors myself, though rest assured I look forward to when it may konk out and now am well equipped to change those parts out given your Guy and Madskp insights.
hope this may benefit others. If you are looking into spare parts I can highly recommend “kose trading”. the manager / proprietor and stands behind his products and services in a delightful and time efficient way. The inventory and supply is vast.
once again thanks for the members of this forum for solving the whole CD debacle with me and for sharing your collective wisdom along the way :-)
