Beosound 4 A-Mem option
Hi.
I want to have one more Audio input in my BS 4, and, as I never use the SD slot, I wonder if it is possible to manipulate somthing inside BS 4, that could enable A-Mem command to an analogue audio input. Eg it could just be a little cable popping out underneath in the connection bay.
Hello. No knowing if it is possible to modify the internals another idea comes to mind.
If you do not have the BS4 connected via Masterlink to a Beovision TV this solution should be possible:
Connect a Beolink converter type 1611 with a Masterlink cable to the BS4. you can then connect a audio cable with 5 Pin din plug (audio signal conncted to pin 2, 3 and 5)in one end to the AAL connector on the 1611.
The BS4 should be put in option 2, so it can receive both audio and video commands.
With a Beo4 remote, press Standby button (the red dot) and List at the same time. Press list again until option is shown and press GO. press list until A.opt is shown. Press 2 and Go
You should then be able to activate the input on the 1611 converter with any video command (TV, V.MEM, DVD etc.)
Hi Madskp
Yhank You very much for Your proposed solution.
I will make use of it, as I have the 1611, and can use 'TV' for getting sound from my Sony TV- line out, and then still have 'A-Aux' for audio streaming input.
Thanks again.
BR
Poul
(Denmark)
Glad to help and great that this was an easy solution for you
