This is my first post so hopefully the posting goes well.
After seing a video on replacing the laser on a Beosound 9000 MK2 decided I could do that,
purchased a laser and off we went. The process seemed to go well but on reassembly no laser function,
unit is not dead display comes on,can switch between radio cd etc.
I hope I have just blown a fuse but cannot find any information on the web to how I can access them.
I removed all the screws on the backplate but the plate did not come away. Probably there's a fastener
hidden so put everything back together.
So my plea can a generous person(s) help and tell me how to access the fuses. Also it would be helpful
if a fuse has gone, what is the replacement and where can I purchase them.
If the fuseses are fine payback to me will probably be a hefty service bill for repair. Never too old to
learn from your mistakes.
Many thanks
Beosound 9000 fuses
