Beosound 9000 MKII broken...
Hello everybody,
My Beosound 9000 is broken... I try to fix it but I am struggling to find the service manual for MKII version. I have MKI and MKIII but that's not match.
Do you know where I can find it? It will be very kind.
Thanks in advance !
Pierre
Hi all and happy new year !
I have found a service manual for my MKII BS9000. But the quality is really poor... I can't read several diagrams. Especially the Diagram J
Does anyone knows where I can find a good quality version ?
The MKI and MKIII service manual are too different to be used.
Thanks in advance
Pierre
is this it?
/api/files/bbe9de03785a4b4e87304930775a3538
Thank you very much for your help !
This is the document I have got. You can see that some diagrams can't be read.
I think there is only this version avaible on internet...
Seems ok to me as it's a PDF and can zoom in. Which pages are you having trouble with?
This is PDF indeed, but made from a low quality scan.
See the attachment. It's zoomed part of page 2-10.
/Les
Lesbart, this is exactly the problem.
If I mix MKI and MKIII service manuals, sometimes I can find what I am looking for, but not everytime.
