Hello everybody, I have this issue with my beosound 9000: Whenever I try to play a CD, it picks up the CD, makes some clicking sounds, rotates the CD only a few degrees in both directions, puts it back and then the sledge moves into position 1 again. It almost seems as if the beosound shuts down and restarts when trying to play a CD. https://youtu.be/0ez5-WE2ucI Interestingly I have the same issue when running the test-modes 71, 72, 73 or 65: It makes some clicking sounds an aborts the test mode (also seeming to shut down restart). Of course I have already cleaned the door sensors and also the lens of the laser. Has anyone had the same problem? To me this doesn't look like a problem of a defective laser. I'm wondering if there is one of the motors causing a short circuit so that the beosound shuts down?
