Beosound 9000 Option setting.
Hi alls, I know this must have been discussed somewhere but all my search came back useless. I have an 9000 connected via aux.out to a Playmaker. I'd like the playmaker repond to usual IR commands and the 9000 – which I use less – respond to Link commands (to my understanding press "Link" + "CD" etc…). First, I dont know which option is that. Second, The IR option setting desnt seems to work (no blinking led on the 9000). Dummy Beolab plug is on. Thanks for the help.
Hi Guy. SW 2.0. A.Option setting to 4 does not work : 1,2 & 5 or 6 do work. I've always wonder how those kind of detail could be relavnt for anyone. Now I know! Thanks Guy.
Well. Here is the setup: Playmaker. Receiving Airplay broadcast and BS9000 into Aux.in. Playmaker must be the main IR controlled device because my phone keeps corrupting airplay reception and also because autosense don't work that well. But then A.Aux or any audio command like CD to select the line IN of the PM also select that source on the 9000 making impossible to select Line IN in the PM and CD on the 9000. So in short, I'd like to be able to select independently PM Line.IN, PM Airplay, BS Sources at least CD and AUX.* An Idea Somebody? Thanks in advance. *Because 75% of the time music is Airplay, I'd rather not to have the PM as a slave for the BS Implying that tha BS has to be on everytime.
Maybe put the Playmaker in A.OPT 4 and use a second Beo4 remote in permanent LINK mode.  Far from ideal, but I am struggling to think of another solution!
When in A.Opt 4, does all command  need "Link" pressed before or do some commands like Volume and Mute work as usual?
Thank you to the Men In Black Boxes Team! I'd like to not add another box to the setup. It already has a Beolink passive that drives Beovox C-40 in the back from the Playmaker Powerlink out. The less bad option would have been using a Beo4 to command the 9000 and the Playmaker in Option 4, not the more convenient but at least just one remote. The problem is that I dont use Beo4, I use a Beolink 5000 I find nicer. Another solution would be a fine programming of a Beo6 but I keep that for later. Thanks again to you both.
