So I was eying the Beosound Level for a while but held back since it would not integrate with my Essence pending Software upgrade.
I lost a bit track but the US site is still talking about pairing with chromecast and airplay. Did that rumored update nor materialize?
Other question I have, I would want the google less version, Is pairing 2 in Stereo working nowadays, specifically with Spotify Connect?
Best
JK
Beosound Level
Hi JK,
I’ve tried to link in YouTube links that the forum didn’t allow to post here.
The Level now supports:
- Spotify Connect
- stereo-pairing using the native B&O app (note that you need two of the same version, so either two Levels with Google Assistant or two without)
- Beolink Multiroom using the native B&O app, so you can now connect to your other B&O devices that are pre-Mozart and Beolink-enabled.
My two non-GA Balances that I have work flawlessly both in multiroom and stereo (as you probably know the Balance like the Level uses the Mozart platform).
Hi JK,
I myself have two Balances which use the same Mozart platform as the Level and while I don’t use Spotify a few months ago B&O released a big Spotify Connect update so I think it should be supported on the Level now. I’d say it should work in stereo even if the B&O website doesn’t mention it specifically here other than that the Level supports Spotify Connect:
https://support.bang-olufsen.com/hc/en-us/articles/4418029319825-Does-Beosound-Level-support-Spotify-Connect-
John from B&O Manchester gave an update on the latest way to stereo-pair Mozart products here so that I know from my Balance works with the Level:
https://youtu.be/JkburfkgC7o
B&O Manchester also sums up the other recent big software update that enables Beolink multiroom as well:
https://youtu.be/K97lFWzq4yw
So I think it is very likely that you can now do all those things.
Anybody that can confirm?
