Hi.
Is it possible to set up the Level so that it automatically switches to aux input/line in if it detects a source?
I have a 9000 connected to a pair of Levels, but can’t get them to switch to aux when I play the CDs in the 9000. Thanks!
BeoSound Level Setup
Try to change the line input sensitivity under the sound settings.
Thanks Mbee. I’ve tried setting it to high but that didn’t resolve it.
How are they connected? PL to Aux-in? If so, I'd turn up the volume on the BS9000.
I think it's also possible to connect from the BS's AUX port... you just need to make sure to find an RCA to DIN cable with 4 RCA leads (2 input/2 output). However, as others have mentioned, the BS9000 needs to think it has speakers connected to it.
The auto-sense line-in works fine on my Balance (another Mozart speaker) - I have a turn table connected to it.
