Beosound Moment and Beolink Wireless
The good news for MisterBG is that the Beosound Moment has inbuilt WISA that will transmit to WISA wireless speakers – some of the newer Beolabs have WISA receivers built-in. In order to provide the WISA facility for older speakers, B&O introduced the Beolab Receiver 1, which acts as a WISA receiver and provides a Powerlink output to Beolab speakers.  One Beolab Receiver 1 is required for each Beolab (Left and Right). However (as Beobuddy has just pointed out) the BL5 is incompatible with Beolab Receiver 1.  This is explained in this thread, in which Steve also suggests a workaround making use of the BL5s’ Line inputs: https://archivedforum2.beoworld.org/forums/p/25222/201651.aspx#201651 So MisterBG could either buy a couple of Beolab Receiver 1s and use Steve's workaround, or stick with the wired solution.
https://archivedforum2.beoworld.org/forums/p/25222/201651.aspx#201651 So MisterBG could either buy a couple of Beolab Receiver 1s and use Steve’s workaround, or stick with the wired solution.
@Guy thank you for the workaround, leaving me stuck with my 6 BLW ! Anyone interested ;-D
Hi all ! I am desperately trying to "air" my Beolab 5, linked today (and doing a fine job at it) with powerlink cables, with Beolink Wireless Transmitter / Receivers. Has  anyone already succeeded such pairing ? Pleeeeease, i am going crazy !
  • Beosound Moment functional
  • Beolab 5 functional with Powerlink cables
  • Beolink Wireless Transmitter + Receivers functional + IREye (come from 2nd house, working)
  • pairing Beolink Wireless Transmitter + Receivers is ok (green light on both units going to stand-by red)
  • when i start the BS Moment, no sounds. Then i press the "play" button on the IREye :  both units LEDs turn green instantly but no sound.
No need to go crazy - your 5’s seem to work great……with PL. A connection with a receiver 1 is - with the 5’s - not possible. At least I know of noone, who has made that possible. MM
Can I just ask whether you are talking about the Beolink 'Wireless 1' - the 2006 version with the little switch on the base where you chose whether it is a transmitter or receiver, as described here:
Hi Guy, yes, I have the little switch. the transmitter is on T, the receiver is on R (wouln't pair otherwise i guess ?) thank you for the help !
@Guy @MM thank you for your answers looking at the 3rd paragraph from the end here https://www.beoworld.org/prod_details.asp?pid=1028 i thought that BL5 were compatible, no ?
The Beolink Wireless 1 will only distribute Masterlink, which your Beosound Moment does not have.  You cannot use the Beolink Wireless to bridge a PowerLink connection. Before we suggest solutions, is your intention to have the BL5s in the same room as the Moment, and are they the only speakers that you wish to connect?
@Guy, Thanks. My BL5 are indeed in the same room as my Moment. I have plenty of other BL (1, 3, 4000 + A9) eager to go wireless if possible but my priority goes to the BL5 should i had to make a choice !
