Hello - I am considering a Beosound Stage if it would allow me to share Airplay and Spotify Connect to other products connected on my system (NL/ML converter and a Beosound 9000 and connected ML link speakers).
Is this possible? I.e. be able to turn on the airplay/spotify connect source (connected to the Beosound stage) from a ML link speaker in another room?
Beosound Stage - which sources cannot share to other products?
I don't have a stage, but do have other ASE platform speakers together with multiple NL/ML converters. It's possible to 'Join' an existing NL playback (such as airplay) from a ML speaker (such as the BL3500) providing the NL/ML converter is configured as the Audio master. The Airplay stream has to be started before you can join. Unfortunately it's not possible to map Spotify or airplay to ML sources. B&O radio and Deezer/Music can be mapped, as well with TV sources (I have a beovision 11 and have DTV mapped to Apple TV), so I assume you can do the same with the stage's tv sources. I hope that helps.
