Hello,
as I got a BeoSound Stage for a very good price before the price increase I now need a new TV for my home office ;-)
On the B&O website it is said that you can control LG C9 OLED TVs with the BeoRemote one. As I have various BR1's lying around I want to use one of these to control my setup. As it seems the C9 are pretty expensive I wanted to ask if this options is only with C9s from LG ore if I can also use other LG models or even other brands.
br and thanks for your help guys
BeoSound Stage and compatible TVs
Hello Tim,
congrats with your purchase. B&O has listed all compatible tv’s with Beoremote one integration. It is basically only LG (Oled) from C9-version onwards.
See at the bottom of this FAQ all compatible tv’s:
So C1, CX and C9 are supported but no C3?
Is this a real technical limitation or might other LG OLEDS also work?
The remote control must be paired to the soundbar, which in turn will control the television via the HDMI and LAN connections between the two. The soundbar is responsible for a lot of information exchange between the remote and the television – for example, it will populate all the source lists and List menu items on the remote control. Even if it is possible to pair it directly with the television (it will pair with other equipment such as Apple computers), you likely would miss both essential as well as nice-to-have functionality.Location: Denmark
Human interface designer at Bang & Olufsen.Thank you. In other words, any LG TV settings: contrast, brightness, sharpness, zoom and others are possible with the help of the BR1 remote control, but only when it is connected to B&O equipment. Or using BR1, it is only possible to adjust the sound and sources, and the picture settings of the LG TV are possible only from the LG remote control?Thanks for all your Help. So basically when I use a LG OLED Tv with my BeoSound Stage the whole Setup has the same user experience as using a BeoVision TV? I am currently struggling with a Decision, whether to go with a C2 or C3 OLED as the difference seems not to be big but price difference is 500 EUR. For the Office Room the TV is not the most important thing ;-) One other thing. When I use the Setup with an integrated LG OLED, is there a way to add a projector? Something like with an HDMI splitter?
