BS theatre, to much bass
system consists of 4x BL 3, BL 19, theatre. Tv LG G2
especially with netflix/disney+ I experience too much bass. setting done through roomsence. what can i change
what should crossover be on? and the various diversion levels?
do hou have suggestions
Leave the crossover - that will be set at 120hz but I doubt it is your problem?
1. In BeoApp, on the Theatre front page, below listening position
Sound >> Equaliser >> dial down total bass setting.
2. Go to a chosen Listening Position (Video > say)
Open the configuration and find “Speakers >”
Find your BL19 registered, dial-down the dB. This will keep the overal tone but reduce the attenuation, giving a deep but less powerful bass
the equalizer Both in minus 10?
speaker level or redirection level. And value?
Move the base equaliser to say -2
Move the speaker level down as much as you can to suit your taste.
I don’t know the effect of redirection level.
sounds like your BL19 is not taking commands from the Theatre if the bass remains too much
I had a simular problem with a Theatre I had for testing at home. My one was faulty and went back to B&O for repair. The Bass was by far to much.
Hi Zwaan,
Welcome to Beoworld!
First, I suggest you turn off Loudness in the B&O app, then either set bass to -1 and treble to 0, or set bass to 0 and treble to +1. This should give a good sound balance with the Theatre for most setups, then tweak the sound from there to suit your ears and preference.
Kind regards, Steve.
Some things to try (including some repetition from the above):
- Don't change the crossover
- Don't change the Re-direction Levels (as a first step, at least)
- Don't turn off the Loudness
PLEASE READ before sending me a Personal Message.
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
