Hi guys,
I have a problem with my MK 1 and unfortunately the site service manual is not complete. Does anyone of you have the schematic relating to the power board? It´s the circuitry relating to the voltage generation around the LM3578 (there are at least 4). Unfortunately the MK2 and 3 are completely different thus I cannot use those manuals as help.
Regards,
Staffan
BS9000 MK I - power PCB schematic
Staffan,
Apologies for the late reply.
As the BeoSound 9000 Mark 1 manual is about 2 cm thick I just scanned the power supply section which is below and attached in a PDF. Click on the image to see it in large format. Login to view image
Excellent Keith! This is the schematic I need! Would it be possible to copy the related PCB to allow me identifying the components on the board?
Many thanks in advance!
Staffan
If I wasn´t clear enough, the service manual also show the layout of the boards. I would need a copy of the Power Board layout to clearly identify the components in the schematic :-)
Luckily I have a working Beosystem 6000 which is doing it´s service of entertaining us :-)
Regards,
Staffan
Sorry my mistake Keith. I checked my data again and found the PCB layout I needed.
Regards,
Staffan
