Does the Beosound 9000 read CD-R's?
Would be nice to know if anyone can help out.
Alas, a few of @matador's additional photos didn't survive in the archived forum, but here is a second thread, which describes the process: https://archivedforum2.beoworld.org/forums/p/42927/311741.aspx (Note if you try it yourself: Avery # 8960 sheets have the smaller die-cut center circle.)
Yes, it does! At least MK2. That one had the laser lens replaced but I also tried with the original laser that I put into an Ouverture Unit and it works too.
Im planning on getting a MK3 with a new laser so fingers crossed. What are those disks you have? are those CD-R with that pattern or did you print custom decals? They look awesome.
Custom… Something I was into when I get my 9000… See
Does anyone have the artwork above in high res?
