How disconnect multiroom on Beosound Essence and remote
Hello,
How to disconnect multiroom
on Beosound Essence
and remote essence ? Cause I have no
multiroom only Beosound Stage and
a Beosound Essence.
Hi gumbots
Actually you have ‘a Beolink multiroom’.
Your two devices - Stage and Essence - do build a B&O network assuming they are on the same home network.
But why do you want to disconnect?
Thanks Millemissen,
'Cause I don't need à Beolink multiroom they are in the same room. Yes Essence and Stage are on the samedi Net work.
Then just use them independently - nothing forces you to use multiroom.
P.S.
I suppose that you have speakers connected to the Essence.
What does the Essence Remote control?
Good morning Millemissen,
Yes I have speakers connected to Essence. I see the Essence Remote control only The Beosound Essence.
What is it that bothers you, what do you miss???
I guess I fail to see your problem.
Maybe someone else can chime in here.
Hi Gumboots, I have the same question.
Since Millemissen is curious as to why, not that it matters, at my end, I'm trying to undo Multiroom and then re-set it up as I'm not seeing the same image I saw earlier with the first set up in my B&O app.
Maybe someone out there knows. If not, I'll just ask B&O support. They're pretty good at replying quickly and professionally. If I find out, I'll post again.
