Intermittent buzzing on Overture
Dear all. Thanks so much for the advice on the screws earlier. The reconditioned overture occasionally makes a sort of raspy buzz. It's quiet, when the CD is playing, and isn't a big deal when the volume is up. Any thoughts?
Hello Matt,
Not so easy to judge from your description I think. You write that it has been reconditioned, would it not be an idea to record the noise (maybe even film the Ouverture when it happens) and ask the seller/reconditioner? I would say that if it was sold as reconditioned to you, it should be working flawlessly, and the seller should feel responsible for it.
Regards, Johan
Some electrical appliance nearby? A refrigerator, perhaps at the opposite site of the wall?
Bad Powerlink wires? Are they original? Long? Short?
A telephone can make this noise when it checks the net connections.
"Bsssss bada bada bada...."
Even a brandnew Overture will show this sound, it was never designed to withstand this emv noise.
Also a computer or router can cause these problem, also some bad LED lights from fareast...
