Lossless Apple Music to Beosound core?
If I have understood correctly, Airplay 2 is not lossless. This means that if I am using Apple Music on my iPhone and transmitting to my Beosound Core via Airplay 2, I am not listening to its full potential.
what I have done is that I run a toslink cable from my Mac mini into the Beosound core.
I could also run a toslink from my Apple TV into the Beosound core.
is there any other way to get a lossless Apple Music signal into the Beosound core?
For those without a Mac……..another way to do this could be to use an iDevice and an external DAC with a lightning input port such as the small AppleLocation: Flensborg————Danmark
Furthermore….those concerned about audio quality should know that one has to change this setting in Apple Music to ‘on’ - by default it is ‘off’. Otherweise it won’t matter, whether you use a wired or a wireless (AP2) connection or not. Login to view image MMLocation: Flensborg————Danmark
And just to make this more difficult, Apple Music is not supported on the older Apple TV models that has optical output.Please Log In to Reply
or![]()
