old Beosound 1 Japan version change radio frequency?
Dear,
I have a old Beosound 1 with Japan version; The radio frequency is like from 76 to 90; Can I change the radio frequency to the normal one like 87 to 108? I do check the service manual that indicating:
(the JP type is: 2584; I think the UK type is: 2582)
Press RADIO due to the following set up of tuner in BeoSound 1. TM is still activated.
Enter TM07. Use this to set up the tuner in BeoSound 1. It is very important to
enter No 1 and Nos 5 to 9 as they are not default set to 000.
No 0 00X X is variant of type.
Look underneath BeoSound 1 for Type No. See 7.
2581=1; 2582=2; 2583=3; 2584=4; 2585=5; 2586=7; 2587=8; 2590=3
No 1 000
No 2 175 FM start. Type 2584=152
No 3 216 FM stop. Type 2584=180
No 4 0XX XX is variant. Type 2583+2590=75, others=50
No 5 000
N0 6 000
No 7 000
No 8 000
No 9 000
- Turn off BeoSound 1. Remember to follow the guidelines in #6 Test after repair of
BeoSound 1
Does anybody have the experience to do this? Thanks!
With kind regards,
Daniel
I try following typing, but it' s not working;
No. 0 = 002
No. 1 = 000
No. 2 = 175
No. 3 = 216
No. 4 = 050
No. 5 - No.9 000
Login to view image Edit: Also if you look at the 'Available Parts' list, you will see that type 2584 has a different part number for the 01Module - the main PCB including radio: Login to view imageLocation: Warwickshire, UK
Hi, Guy,
The manual you mentioned is the service manual or user manul? In my service manual, I can not find the "specification" section. Can you help a little?
Thanks!
Daniel
It was the Service Manual that I took those pictures from:
Login to view image
There is a separate document called the 'Onsite Service Guide' to which you may be referring.
Hi, Guy,
Thanks for your reply! Indeed your manual is right! Looks there are two service manual versions for beosound 1; And I just have the short one.
Now I did have the one same as yours.
It' s great help from you. I will ask my local engineer to change the PCB1 board in physical way.
Daniel :)
