Hello everyone,
I don't know if I'm posting in the right section (apologies in advance).
Owner of various B&O items, this is the second time I've had a problem with the screen of my Beosound Moment.
In 2019, following the appearance of a stain on the screen - which was still working, the device went to after-sales service (Takeover under warranty).
Login to view image
Once again, the stain appeared... and the screen no longer worked (The sound heart is still working as I can see it in my B&O iPhone app).
Login to view image Login to view image
I suspect the battery, because looking at the technical diagrams, it seems to be located where the stain is.
Do you know if this is a listed / known problem or am I just a victim of bad luck?
I like this device - which is unloved, especially as it drives my Beolab 18 and 19...
Do you have any idea of the cost of repairs for this type of problem (€) ?
Thanks in advance
Sincerely
Problem with my Beosound Moment
You Can replace the battery Buy it on ebay.. buut the display, can be done..
