Wall mount for beosound 9000
Hi, first time posting!
So a couple of weeks ago I found a good deal on a beosound 9000 mk1 that I bought.
When I got home I realized that I hade to order a couple of cables and they turned up today which works great, the seller claims that she might have a floorstand in her basement but she cant find it. She sold the CD-player because she is going to move soon so it will probably be found in a few weeks.
Now to the question. I noticed these holes on the back side which look like they are meant for hanging it on the wall. Does anyone know what their purpose is? Can I use these holes to mount it to a wall?
I can confirm that the holes on the back are to allow you to place on the stand or wall bracket
There are three types of stand/wall bracket as below
Login to view image
Login to view image
Login to view image
Ok! Thank you for the reply! I'm still debating what mounting solution I'm going to go for.
As it stands I have three ideas.
1, Wait for the stand that she hopefully finds.
2, Buy a wall mount when I can find one (I've been in contact with a B&O service center that claims to have one but won't give price)
3, Since I have the "knobs" for lack of better words to mount it to the floor stand it shouldn't be a problem to build a mounting brackets for it.
Any input would be much appreciated!
2) They probably want to sell you a new wall bracket from STB. Bottom of the page, here:
https://www.stbbrackets.co.uk/en-GB/products/beosound-9000
Yeah, I saw those, shipping might be a bit expensive, but it's doable. The thing is over all when it comes to B&O is that it is rather expensive. I did build something for myself to hang it off the wall which works great but if I ever come across a wall mount for cheap I might consider it.
I spent about $250 (2500SEK) for the CD-player so adding another £504 for a wall mount feels kinda wrong. I'm not intending to buy anything else from B&O, I'm set when it comes to turntable and speakers and don't really need anything else.
Its good advice to try and find a B&O wall bracket,although alternatives could be fabricated too.
The B&O ones are particularly well made and strong.Remember,it's a heavy unit,so you want it to stay on the wall and not end up on the floor as a kit?
The wall brackets change hands here in the U.K.for about £150.
Nick
