- Reflowed solder joints
- Repaired cracked circuit board
- New capacitors, trim pots, relays, thermal compound
- WIMA caps and updated OPAMPS for preamp
- New trim panel and chassis feet
- Detailed cleaning inside and out
- Adjusted per service manual
- Full (disassemble) cleaning and lubrication
- New capacitors
- New rubber parts: platter belt, sliding chassis belt
- New trim panel, chassis feet and lid bumpers
- Polish dust cover, replace lid damping grease
- New SMMC3
- Repaired laser assembly and deep clean
- New capacitors
- New rubber parts: tray belt
- Repaired power supply
- Repaired tape transport
- Tape transport - Full (disassemble) cleaning and lubrication
- New capacitors, trim pots, thermal compound
- New rubber parts: drive belt, pinch rollers, drawer belt, drawer rollers
- New NOS main drive motor, hot oil vacuum infused bearings
- New board mounting clips
- Repair corroded traces on circuit board
- Disassemble and clean switch pads
- New capacitors
- Replace bad transistors
- New capacitors
- Repair corrosion in battery compartment
- Clean switches
- Rolling OPAMPs in the preamp wasn't fruitful. I could not hear or measure any meaningful difference between the original and a variety of modern chips.
- Acquiring the test/calibration tapes was harder (and more expensive) than fixing the tape deck
- Repairing/restoring something after a botched repair attempt is harder than fixing something that failed due to natural causes. I already knew this, but the tape deck reaffirmed this.
- Restoration parts can cost more than the acquisition price of a component
- One can still put together a very nice, vintage B&O Beosystem from scratch with patience and perseverance.
- Find a solution to the cable mess behind the Beosystem stack.
- Fix the Beogram chatter problem (mentioned in another thread).
- Continue verifying that the system meets the original performance specifications.
