Program beo1000 remote for aux
We inherited an old beosystem2500 from a family member, and a beo 1000 remote. We are using the aux port to stream music to it, and I cannot find where/how to program a button to select AUX as a source. No info is in the manual so I figured Iβd post and ask.
thank you in advance!
The PHONO button on the Beolink 1000 should activate the AUX source
Or press SHIFT then RADIO
(but I agree that PHONO should work too π)
Phono button activates the phono input. It is shift and then radio, not shift and radio at the same time.
This was it. In succession not at the same time.
any way to turn off the lights in the back while itβs on?
also - any idea if the unit has a sleep timer?
thank you again for the help
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
