Apple TV boot delay - beovision 11
Hi all, I bought a used beovision 11 - 40, and I set up the latest apple TV 4 with PUC to control the box with the beo 4. It works perfectly! There is only one small odd: When I boot the beovision from apple TV source, it does not show the beovision opening scene, because I think that the apple tv takes some secondes to boot. So I tried these workarounds without success:
  • I know there is an option to add some "blank delay", and I added some delay until 20 sec, but it does not fix the problem.
  • I used another HDMI and PUC ports, but does not fix the problem
  • I tried to connect another apple tv
  • I also tried with another HDMI cable
  • I updated the beovion with the latest version, and hard-reseted, nothing changed.
  One thing that I noticed: if I boot the tv with apple tv followed by "picture mute", then when I "picture unmute", the opening scene is perfect.   Have you ever seen this issue? I think this problem could also be on beovision avant and beoplay V1; because they all share the some OS.   Thanks,
Not sure what you wanted to see here. Is the "opening scene" the Bang & Olufsen text? I have disabled powersaving on my BV11 setup so when I press my shortcut button on my Beoremote 1 that I have mapped to the AppleTV source, it opens up with the curtain and reveal the AppleTV screen.
Thanks for your answer! By "opening scene", I mean the curtains: when I press the shortcut button from my remote that I mapped to the AppleTV source; it does not opens up with the curtains, it directly shows the appleTv screen. I also don't set powersaving on picture. Did you set any blank delay?   Thanks
0 second blank delay.
Ok, and do you keep the apple tv always on? Do you turn if off when the tv is off?   On my side, I turn it off when the tv is off.   thanks
My ATV is set to be always on. I guess if you have the ATV set to power off each time, the curtain will open prior to the ATV and you will not see that effect.
ok thanks, I ll give a try this evening.
Ok, even if the apple tv is set « always on », I don’t see the curtains. It seems that something adds a delay before showing up the picture. Do you enable Wifi?   thanks
I actually found out that when I switch from apple tv source to another source (radio) it is instant, but when I switch from another source to Apple tv, I observe the same delay (like 6-7 seconds) before seeing the picture. Do you see the same delay when switching between sources?
hi all,   Anybody also seeing this issue?   Thanks
