I would like to know how to install an over the air antenna to my Avant 55, since it does not have a coaxial input. Also, I can’t find a selection for antenna in any of the menu options.
Avant 55 Over the Air Antenna
Sorry, if you're in the USA, you probably already guessed: you don't. Connect a TiVo Edge for Antenna (or an old TiVo Roamio OTA) via HDMI to the Avant. Other countries are different, some even including a dual tuner with a USB recording drive! The 3 coaxial F-connectors, if you had them, would be at the top above the Ethernet jack (Satellite 1, Satellite 2, Antenna).
Thank you. It’s a U.S. version. Looks like I will be going through the HDMI input on the top row of the tv.
