- Type 8870 (1860500)
- Type 8686 (1860408)
- Type 9687 (1857408)
Avant 85" - different types.
Hi all,
I am looking at 3x different types of the Avant 85" TV - does anyone know the difference?
Type number 8686 and 9687 are the same UK product.
I don't know what Type 8870 is, but it is not an AVANT 85 Login to view image
Do you know the differences between the 8686 & 9687?
Attached is the sticker off the back of the type 8870. Login to view image
Wrong photo - try this one :) Login to view image
The sticker images in each posting you made look the same to me...
The type 8870 must I assume be a later version..
That is what I tink (it's a later version) - do you know where I can see what the differences between the 3x versions are?
Beovision Avant was released in 2014
I believe the 85" version came end of 2014 ... Maybe a bit later.
The NG (New Generation) came in 2016.
As you picture says NG - Type 8870 must be the New Generation type.
The NG runs on same platform as Beovision 14 i.e. Android TV. The NG works with BeoRemote 1 BT (Bluetooth instead of IR)
If I google 'Beovision Avant label' I see that type 8679 is first generation.
Hope this information helps a bit.
